$80,000 Gada Prize announced for the first team to build a better RepRap.
Cartesian Bot Variations
From RepRapWiki
This Page Contains multiple RepRap development projects and should be split so that each individual project/design/improvement has it's own development page.
Release status:
Description mods for the darwin cartesian bot
Author [[User:|]]
Based-on Darwin
CAD Model(s) none
External Link none
Weight reduction
Using M3 rods (instead of M8) for the diagonals will reduce the total weight of your RepRap darwin by a couple of kilo's. I don't think this will make much difference in terms of rigidity. If you want to have a more mobile RepRap, this will help a out! You need to add two washers to stay compatible to the [diagonal tie brackets].
Alternatively, we could design printable diagonals. They have to be pretty thick, because plastic stretches a bit. Even a tiny bit of stretching makes the machine less accurate.
Heated base plate
The folks at [Metalab] have had a lot of success with reducing thermal distortion by building on a [heated base plate]. See that link for details.
Personal tools
interaction
