$80,000 Gada Prize announced for the first team to build a better RepRap.
Mendel Y-axis
From RepRapWiki
There are security restrictions on this article
Mendel Build Documentation
You may find the assembly data sheet useful during assembly.
Motor bracket
BOM
Total # of assemblies: 1
Name Qty/assembly Total Qty Type
drive-pulley_3off.par11RP
y-motor-bracket_1off.par11RP
opto-endstop-v2-1-pcb.par11PCB
m3-capx20.par55Fastener
m3-nut.par22Fastener
m3-nylock.par11Fastener
m3-washer.par88Fastener
624-bearing.par22Bearing
m4-nylock.par22Fastener
m4-washer.par66Fastener
m4x40-cap.par22Fastener
m5-mudguard-washer.par22Fastener
stepper-motor-nema17-fl42sth47-1684A-01.par11Motor
Printed parts
Image:y-motor-printed parts.PNG
Assembly
Optoswitch pcb is spaced with two M3 nuts.
Idler bracket
BOM
y-idler-bracket_1off.par11RP
Printed parts
Assembly
Y bearing 360
Two pairs needed, one with a ‘left’ outer and the other with a ‘right’ outer.
BOM
Total # of assemblies: 2
y-bearing-360-inner_2off.par12RP
y-bearing-360-outer-_1off.par12RP
624-bearing.par48Bearing
m4-nylock.par612Fastener
m4-washer.par2652Fastener
m4x40-cap.par612Fastener
Printed parts
Assembly
Before this assembly it's important to understand the key mechanical concepts of how the axes work. If you haven't already, check this video out:
Once assembled, clamp the ‘A’ and ‘B’ bolts tight. Set the 360° fit by inserting a ø8 mm bar (e.g. Y bar) into the bearing assembly. Initially, there should be about a half-mm gap between it and the bottom two bearings when the bar is running on the top two. If this is tight, add extra washers either side of the top two bearings; if it is too lose take some away.
Tighten/slacken the two lower adjuster bolts (‘C’) until all the bearings just touch the rod and smooth running is achieved. Ensure all bearings rotate when the bar is slid up and down.
Y bearing 180
BOM
y-bearing-180-inner_2off.par12RP
y-bearing-180-outer-_1off.par12RP
624-bearing.par24Bearing
m4-nylock.par24Fastener
m4-washer.par2448Fastener
m4x40-cap.par24Fastener
Printed parts
Assembly
5 washer stack either side of bearing. Once assembled, insert a ø 8 mm bar in between the bearings and clamp the slotted bolt to achieve a smooth run. Ensure all bearings rotate when the bar is slid up and down.
Chassis
BOM
purge-plate.par11Sheet Image DXF
y-chassis.par11Sheet Image DXF
y-flag.par11Thin sheet
y-belt-clamp_2off.par22RP
y-bearing-180-left.asm11Assembly
y-bearing-180-right.asm11Assembly
y-bearing-360-left.asm11Assembly
y-bearing-360-right.asm11Assembly
m3-capx20.par44Fastener
m3-nut.par44Fastener
m3-washer.par44Fastener
m4-nylock.par2020Fastener
m4-washer.par4040Fastener
m4x16-cap.par44Fastener
m4x40-cap.par1616Fastener
Printed parts
Assembly
Ensure all bolt heads sit on the underside of the chassis and bolt shanks point up. This guarantees that the chassis assembly will not collide with any of the frame structure it moves in.
Put the Y-axis ground rods through the bearings before tightening them. This ensures everything is aligned.
Bed will be attached later.
Back to Mendel mechanical construction root.
Personal tools
Advertisement
